Is a lens filter required?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Oracle_OSS, Jun 7, 2003.
  1. Oracle_OSS
    Oracle_OSS
    I've just bought a Sony TRV250e. This is my first camcorder. Could anyone advise, do I need a lens filter? I read that this is required, but I enquired at my local Sony Centre and they said this was not necessary, if it was it would have been included in the bundle. Also, is it really worthwhile dishing out another £80 or so on a spare battery? Any advise on this would be most appreciated.
    Oracle_OSS.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    A spare battery will give you a lot longer running time. The battery supplied normally only lasts for around an hour. If more is required then you will need to get another battery.
    I always put a filter on all my cameras. If the £10 filter gets damaged then throw it away and get another one. If the camcorder lens gets damaged then it is an expensive repair.
    Mark.
  3. Duster
    Duster
    Dec 4, 2002
    421
    UK
    As Mark says, get a UV filter as its not worth the risk of a scratch to the lens of your camcorder
  4. Eee-Tee
    Eee-Tee
    Sep 17, 2002
    153
    Hyde, Manchester
    Oracle- Yep, check out the size of the lens on ya cam (says it on the front) and get a UV filter- one of the most useful things you can buy.....:D
