Is a dig coax cable and sub cable the same ?
Discussion in 'Cables & Switches' started by common, Jul 26, 2005.
  1. common
    common
    Mar 5, 2001
    1,384
    41
    Oxford UK
    +8
    As title really, was going to buy a new sub cable then noticed in a shop it said suitable for connection from DVD to AMP or AMP to Sub
  2. dj_johnnyg
    dj_johnnyg
    The cables are basically the same, just a phono plug on each end of the cable.
    The difference is probably the quality of the cable used & the connectors. As you may know, the 3 phono lead you get with most AV equipment does the job, and it doesn't matter if you plug the yellow video lead between the right or left audio, you still get a signal.
    That's a thicko's guide, as that is about my level, but I'm sure there is a more techie person out there who can eloborate further....
  3. demostenes
    demostenes
    Some manufactures say that the sub cable are built to handles low frequencies better ( better noise rejection and higher bass response). . . don´t know if this is entirely true but the sub and RCA cables have somewhat similar prices so i believe its worth the extra 4£ :)
  4. common
    common
    Mar 5, 2001
    1,384
    41
    Oxford UK
    +8
    Thanks -it's just that I have a spare good quality digital coax that I could use to save me spending £20 on a sub cable
  5. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    just make sure the screening is top flight....
  6. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    The answer is acutally no: a sub cable has an impedance of 50 Ohm (like normal interconnects) while a digital coax has an impedance of 75 Ohm.
    However if using a dig coax as subwoofer cable makes an audible difference might be debatable.
