Is a 300w sub to much for a small room?
Discussion in 'Subwoofers' started by guyb, Jun 9, 2003.
  1. guyb
    guyb
    May 20, 2001
    642
    Leamington Spa
    +5
    Hi All
    Do you think a 300w sub will be to much in a small room? I don't want to be over powered by thud and bass but I am not happy with the 100w sub I already have.
    Guy
  2. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    It is more to do with subwoofer design that output of the amplifier. The original Q Bass was quite a powerful subwoofer with it's 40 watt amp.
    If you buy a "better" sub rather than just a more powerful one, you can always turn the volume down as depth and control are more important than outright volume anyway.
  3. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    I would be more concerned about the driver size of the sub rather than the wattage. More power should simply lead to less distortion at a given volume (all things being equal which they rarely are). What sub were you thinking of and what is the size of your room?
  4. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    The simple answer is no IMHO. I use a Velo CHT-15 in a room 13'x14' and it's in no way overpowering.
    There's just one caveat of course, make sure you have it set up correctly in the first place. The sub is only ever as loud as you choose to make it, if you crank the sub volume to 9 and listen at reference level then don't be surprised if structural damge ensues!
  5. guyb
    guyb
    May 20, 2001
    642
    Leamington Spa
    +5
    Jeff
    I was going to buy a second hand Kef TDM45B from someone I know.
    It has a 15in driver!
    The room is about 4.5 m by 7m.
  6. nathan_silly
    nathan_silly
  7. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    Not exactly a small room... ;)
    A 15" sub should be fine, especially if pointing long ways (i.e. its got about 7m before it hits the back wall).
  8. guyb
    guyb
    May 20, 2001
    642
    Leamington Spa
    +5
    I probably exaggerated the room size, thinking about it the room is probably between 4m by 5.5m to 4.5m by 6m
  9. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    Yep, the specs for the TDM45B have always confused me - it's a 300watt 15" model that is THX certified (can't remember the requirements for THX ultra but I'm sure it was a lot lower than 35Hz) and yet the official stats (as Nathan says) state 35Hz - then again that KEF page also says "Extending right down to 15Hz".
    I don't think there's any doubt that it goes deep - I have however heard from someone else that it's not the "fastest" in the 40Hz + range making it much more of a movies than a music sub. If you just want it to move air though then it won't disappoint.
    Matt.
  10. Paul Smith
    Paul Smith
    Apr 15, 2002
    2,040
    Berkshire
    +142
    I believe the THX spec called for a range of 30hz - 80hz, which was not that strict, but the Kef still doesn't manage it, (which always puzzled me as well).
    I am sure room gain would help it's in home response, but for me I prefer something which reaches deeper.
    I have not yet had a problem with a big powerful sub in a relatively small room, it's the setting up which matters most.
    Paul.
  11. Supernosh
    Supernosh
    I'm using an ASW675 with a 500W amp in a room about 12x18 and once I got the setting right it is well sweet!!
  12. BadCamper
    BadCamper
    I currently employ a 12" 400W subwoofer sub for a 5.5 x 4.0 meter sized room.
    As others have mentioned, I keep the volume well below the maximum, dropping the decibal level on my receiver for the LFE output -8db and having the low-pass frequency knob turned to its lowest setting of 50Hz.
    I've listened to movies at "regular" volume settings and the thing was just too rough. I even broke a shotglass once as it was rattled off a table and fell to the ground!
