Is 6.1 really that much better then 5.1?
Discussion in 'AV Receivers & Amplifiers' started by hunkiemunkey, Mar 18, 2003.
  1. hunkiemunkey
    hunkiemunkey
    Jul 17, 2002
    88
    Hi there
    I am about to buy a Sony STRDB780 (5.1) and am wondering if it is worth paying an extra £100 or so to get an 6.1 amp. I know it would be more futureproof, but I couldn't justify the cost if it would only make a small difference
    What difference the 6.1 make to the sound?
    Also, what does the 780 sound like on music?
    Many Thanks
    John :clap: :eek:
  2. nhk
    nhk
    Dec 30, 2002
    82
    I have a 6.1 setup and honestly cannot see much advantage over 5.1. To me I did it at the time of setup and only the cost of the added speaker was at stake (using 3803 amp).
    Perhaps I am setting up something incorrectly and others can tell me what I need to do.
  3. calibos
    calibos
    Aug 4, 2000
    931
    Ireland
    +33
    I just got a Sony 1080 6.1 and in my set up it doesn't make that much of a difference, but my room is only 4m x 2.5m. I new it wouldn't make that much of a difference before I upgraded and I was only really doing it for DPLII and the colour(Silver). I think that in a larger room where your rear speakers are on opposite walls a fair distance apart there can be a 'hole' where the stereo image from your rears don't meet in the middle leaving a 'sonic gap'. In this situation a centre rear channel fills in this gap in the rear stereo image.
  4. superaffordable
    superaffordable
    Sorry for using this thread with a topic that has not been intended for.
    Keith, how about DPL 2, has been worth it the extra money agains the normal DPL?
  5. Silent Fly
    Silent Fly
    Yes. There is no comparison with DPL.:eek:
