Is 480 pixels really enough (PW6)
Discussion in 'Plasma TVs Forum' started by johnmreynolds, Sep 23, 2004.
  1. johnmreynolds
    johnmreynolds
    Sep 23, 2004
    33
    +5
    I've decided it's finally time to get a flat screen TV. I'm primarily going to be using it for displaying PAL DVDs, but also need to show Sky, NTSC DVDs, consoles and PC output (for video only, not PC applications).
    After reading these forums for a while, I had decided on the Panasonic 6 series Plasma as it is consistenty recommended for its image quality.
    However, I'm now having second thoughts. Is 480 pixels really enough for a good picture from PAL sources? Presumably it must downscale even standard definition PAL signals? Does this add significant blur? Is this particularly bad for console games?
    I'm now tempted by the Sharp LC37HV4E as this can be got for £2500 including a three year warranty offer from Sharp. This isn't much more than the Panasonic once you add the cost of a stand and the warranty. It also has a much higher resolution.
    Unfortunately, I've not seen that many authoritative reviews of the Sharp screen with regards to picture quality.
    Does anyone have any better suggestions in this price region?
  2. ReHaBWales
    ReHaBWales
    Jan 7, 2003
    112
    16
    Not sure about the price of a stand ...but a warranty with Richer sounds is £169.99 for an extra two years on top of the standard year.
    After veiwing several Plasmas including ones with Higher resolutions I found the PW6 to have the best picture....but I guess this depends on what you're using it for. If you have HD sources then you might be better off with a screen with a higher res.
    I went through the same process a few weeks ago but I decided that given the lack of HD material and the fact that I will be watching SKY aor DVD's then a SD screen is the better option anyway. SD is actually closer to the resolution of DVDs so there is less conversion with a SD than with a HD. A HD screen has to "fill in" the picture information that is missing. I haven't seen one HD screen that does this very well. In fact the best I've seen is the Panansonic PHD and even that doesn't look as good as the PWD with a SKY broadcast.
  3. oreoboy13
    oreoboy13
    If you can afford a scaler aswell - get the PHD6 or wait for the PHD7
  4. Tonester
    Tonester
    Don't go purely on number of pixels - have a look at some TVs in the flesh before deciding I'd say.
