Is 4*AGP much worse than 8*AGP?
Discussion in 'Desktop & Laptop Computers Forum' started by cameronl, Jul 30, 2003.
  1. cameronl
    cameronl
    Aug 13, 2002
    1,146
    38
    +11
    hi there all, I have decided to get my self a new computer. I really like the look of the Soltek Qbic Barebones System.
    http://www.overclockers.co.uk/acatalog/Soltek_barebones.html
    However, I see it only has a 4*AGP slot. I want to buy a Radeon 9500 for games - will the 4*AGP be much of a bottleneck or am I better of choosing a motherboard with 8*AGP?
    thanks
    CaM
  2. Hawklord
    Hawklord
    Feb 15, 2003
    3,424
    Aldershot, Hampshire
    +257
    I do not notice any performance increase between 4x and 8x with my mobo/g card. Modos an abit nf7-s and g card is an ati radeon 9700 pro. I would think the 4x would suffice but for mobo longevity might suggest you get the 8x spec for any g card upgrades you may wish to take advantage of in the future.
  3. HMHB
    HMHB
    Nov 11, 2001
    25,446
    Nottinghamshire
    +3,750
    I think that the games have to be specially written to take full use of 8* AGP (I'm sure someone will correct me if I'm wrong!!) so at the moment I can't see it making mych difference at all. But, as Hawklord points out, an 8* AGP slot will give you more longevity - if there is such a thing in the computer world ;)
    I'm sure Intel are planning to bring out PCI Express in the near future which will do away with the AGP slot altogether.
  4. cameronl
    cameronl
    Aug 13, 2002
    1,146
    38
    +11
    hi there guys, thanks for the info. From what you have said I'll get the 4*agp with the radon 9500 then.
    thanks
    CaM
  5. manc
    manc
    Apr 3, 2003
    150
    19
    There is hardly any difference whatsoever in any benchmarks, I have owned many cards including my current radeon 9700 pro 8x , If you turn it off there is no noticable difference.
  6. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    nope, no difference.
    the only time the agp transfer rate comes into play, is when you run out of graphics card memory. and seeing as most modern cards have 128mb+ on board, that happens rearly, if at all.
