Is 1080p the end of the road for home viewing?
Discussion in 'General TV Discussions Forum' started by expat, Dec 3, 2004.
  1. expat
    expat
    Mar 17, 2003
    500
    Berlin
    +40
    Is it reasonable to assume that the improvements in resolution for home viewing display devices will end with 1080p, given the limits of human visual acuity, typical viewing distances and desirable screen sizes?
    I for one would not want a display larger than 50" in my living room. With a viewing distance of 2.5m (8 ft), any resolution beyond 1080p would presumably make no perceivable contribution to PQ.
    expat
  2. beeblebrox12
    beeblebrox12
    I think it is. Thinking how the miserable NTSC existed for more than half a century and is still good enough for some people, 1080p should be more than enough for even the most discriminating tastes for the next few decades.
    Unless, of course 3D comes in :)
  3. kurdt
    kurdt
    Naah, I think it isn't really the end. We just don't have better at the moment so it seems the end. Remember when you saw DVD for the first time and at the time you watched VHS, it was soooo good :) Now it's just standard and lowest quality you expect from new films. There's still usable resolution in 35mm film. When film and movies really look like real life, that's the end.
  4. Rob20
    Rob20
    Jul 3, 2004
    3,087
    +659
    Isn't there already a new standard for professional cinema broadcasts. 3840 by 2160 or something. Other than that, they could increase the frame rate. Perhaps 50 brand new fps rather than just 25 shown twice per second as is currently the case. Would be good for sporting events where fast moving objects lead to blurring, picture defects etc.
  5. beeblebrox12
    beeblebrox12
    You can't make the analogy with DVD. We are talking physical dimensions here. 1920x1080p is really too much for maybe 99% of viewers. They won't have enough space/money/desire to upgrade even to 1080p within next 20 or so years, let alone wish for something of even higher resolution. Even the most discerning home cinema lovers will not want to pay for more detail, and they will be less than 1%. The most I can see happening is a new 1080p@60fps standard, but that will be just higher framerate, not resolution.
    As it's already been mentioned, real movie theatres are a completely different story. Unlike home theatres, there's no limit so size hence more resolution will always be welcome.
  6. MR151
    MR151
    "1920x1080p is really too much for maybe 99% of viewers."
    Not for me. :D
  7. kurdt
    kurdt
    Yes, but what I meant is that 1920x1080 isn't really the best they can pull out of 35mm film. It can always be more accurate with details and colors can be more "truthful". Even with 1080p plasmas, you can see "pixels" if you know how to look and where, so if that's the end, I'm disapointed :)
  8. jgrg
    jgrg
    Oct 19, 2004
    556
    28
    Cambridge
    +36
    It is definitely too expensive now, but don't underestimate how fast prices can drop in a few years.
    James
  9. Rob20
    Rob20
    Jul 3, 2004
    3,087
    +659
    Perhaps 3d tv is the future? or perhaps images will be transmitted directly to our brains? Who knows? :laugh:
  10. GrahamC
    GrahamC
    Jul 22, 2001
    2,259
    Morecambe, U.K.
    +67
    Increasing resolutions will never end; they have to sell you something.
  11. mattmarsden
    mattmarsden
    Mar 6, 2002
    1,546
    48
    +98
    I may be wrong, but I thought George Lucas shot Epsiode II in 1080P? If this is the case then, for this film at least, there is no need to go higher than 1080P.
    I think 1080P resolution is probably as good as we need, I think improvements can be made in colour accuracy and encoding artifacts.
  12. Rasczak
    Rasczak
    Apr 3, 2002
    21,687
    Warwick
    +2,560
    Yes - and the BBC made early Doctor Who episodes in black and white - but that didn't stop progress!
    High Definition is good, but Ultra High Definition will be better. As more and more people get plasmas/LCDs/projectors etc people will appreciate the higher resolutions - especially as high resolution panels get cheaper. BluRay has already got an eye on the UHD - you don't think 200GB/8 layered BluRay disks are for HD do you?
  13. expat
    expat
    Mar 17, 2003
    500
    Berlin
    +40
    My original point was that any differences in PQ caused by resolutions beyond 1080p would not be perceivable on displays for home viewing (assuming a maximum display size of 50" at 2-3m viewing distance). The human eye can only see so much detail!
    Only for a more cinema-like viewing experience (larger screen etc.) would higher resolutions make any sense at all.
  14. dvdmike007
    dvdmike007
    so why have more than a 2mp camera ?
    try "4096x2048, or IMAX-class quality"
  15. Abit
    Abit
    Jul 28, 2004
    222
    16
    California, USA
    One only needs to see a 50 inch blowup of 35mm film and a blowup from medium or large format film to see that there is plenty of room for improvement.
    I scan my 35mm film at 4000dpi (approximately 5670x3800) and the detail far surpasses anything you would get from 1920x1080, and it certainly would be very noticeable, even on small screens.
  16. rogeralpine
    rogeralpine
    Oct 28, 2002
    570
    16
    Who knows where progress will take us? I certainly see big differences in image quality when looking at lower resolution digital pictures as opposed to the really high definition images - as long as the source hardware does a good job that is.
    Due to the time current TV broadcast technology has been around, it's going to be another generation (20 years at least) before further advances start to show in the home. I personally would welcome advances over 1080p - but it will certainly do for the next couple of decades.
