is 100mhz really worth it???
Discussion in 'General TV Discussions Forum' started by BlinkzExtreme, Aug 10, 2001.
  1. BlinkzExtreme
    BlinkzExtreme
    hey guys,
    i'm lookin into gettin a 32" soon and I', not sure wot i'm gonna get. Wots all the fuss with the 100mhz? my parents have got a toshiba with it and i think the picture is nasty, loads of blurring and artifacts etc. I think i'm just gonna get a nice normal widescreen. wots the best none 100mhz 32"?
    is the JVC 32WFT1 any good?
  2. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    I have the 44ps2 also and have a Kef kht2005 sitting on top mine.Looks and sounds lovely
  3. glen61
    glen61
    How does your center speaker stay on top?<br />my KLH center is about 1 meter long?<br />dont u use the tv 4 your center ?
  4. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    The Kef sits perfectly with the angled foot.<br />Obviously it's also a better quality speaker than the standard set ones.<br />I also use my system to listen to the radio,cd,sacd etc so in order to have the center speaker operating I would have to have the tv on(If I were using the tv's ones)<br />Just a point of note,I noticed the standard sets speakers are not magnetically sheilded,which seems very hard to beleive as they are only 6inches from the lamps.So I removed them.(dont use them anyway)<br />Incedently after removal the convergence was quite a way out.So they was having an effect on something.<br />I've checked the geometry/convergence with video essentials and all is now o.k<br />Simon
  5. glen61
    glen61
    simon thanks for the speaker tip<br />im now going to get my screwdrivers out<br />and have a dig around!<br />its a shame sony hasent got this right this time<br />as the tv isint exactly cheap
    <br />glen61 <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0">
  6. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    To be quite honest I couldn't beleive it at first,but the post speaker convergence seemed to prove it.
  7. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    Hi<br />Obviously you mean 100hz.Your best bet may be to but a set with 100/50hz switchable.That's what I have just done,you can then choose if and when you want to swap them.
  8. glen61
    glen61
    yo<br />ive just broght the new sony kp44ps2 which has <br />swithable 50/100hz good tv but a pricy at 2800<br />quid it can also be switched to be used as a center speaker which is handy,as theres no room on top for one?
  9. glen61
    glen61
    Ive emailed a nice letter to sony uk,<br />about the problem,<br />let you khow the results when i get them.<br />glen61 <img src="wink.gif" border="0"> <img src="tongue.gif" border="0"> <img src="wink.gif" border="0"> <img src="tongue.gif" border="0">
  10. webster
    webster
    Have just got a JVC 32WFT1 - VERY impressive picture. Only one RGB scart, so I bought a switchbox to connect DVD / Digibox and Playstation to it.
    Highly recommended.
    simon
