Irman
Discussion in 'Desktop & Laptop Computers Forum' started by kevshed, Mar 20, 2003.
  1. kevshed
    kevshed
    Oct 30, 2002
    1,248
    48
    bournemouth
    +98
    Hi guys,
    Can anyone suggest a place in the UK i can buy a USB IRMAN... or suggest an alternative... ive had a bit of a hunt, but with no luck.
    Thx
    Kev
  2. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    Was just about to log on here and post exactly the same question!:)
    I don't fancy getting stung for a £10ish handling charge by whicnever courier brings from the US.
    Mark.
  3. Underscore
    Underscore
    Mark,
    I'm not sure you'll need one. One of the questions that I asked Nebula was whether the remote can be used to control other programs and the answer was that v2.0 (available for download next week) will support that.
    HTH,
    _
  4. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    The IRMan is also for remote control of DVD S/W, MP3 Jukebox etc. as well as the Nebula card.
    Will the nebula card also support IR control of other programs?
    Thanks,
    Mark.
  5. Underscore
    Underscore
    That's what they claim. To quote a snippet from the mail that they sent me:
    So it may be worth waiting for a while...
    _
  6. Kramer
    Kramer
  7. Kramer
    Kramer
    echo!
    :rotfl:
    You're welcome :clap:
