Iriver h320 help
Discussion in 'Headphones, Earphones & Portable Music' started by ETexists99, Jan 5, 2005.
  1. ETexists99
    ETexists99
    I got a knew iriver h320 for christmas and i went to school and droped it by accident :oops: . Now it dosnt play half the songs, and when i hook it up to my computer using the usb cable, my computer freezez. It also dosnt display my photo's ethor? Any idea's? :lease:
    THX
  2. mattross
    mattross
    Oct 23, 2004
    257
    +6
    If there isn't any cosmetic damage to the outer casing, contact iRiver and get it replaced as faulty.
  3. ETexists99
    ETexists99
    i formated the drive and i figuerd that it only scipps 11 songs out of like 59. so it has to be the hard drive!
    THX
  4. Tony8377
    Tony8377
    Aug 19, 2004
    878
    Essex
    +4
    If damaged you could probably claim off your home contents insurance if you have cover outside the house and your retention isn't too much.
  5. ETexists99
    ETexists99
    ok, i was going to return it saterday for another h300 series
    THX
