irbus.sys xp pro file required
Discussion in 'Desktop & Laptop Computers Forum' started by Stellavision, May 12, 2005.
  1. Stellavision
    Stellavision
    Apr 7, 2003
    2,190
    Southsea, UK
    +76
    I am interested in using the MCE remote with Media Portal within XP Home.
    Apparently I need the irbus.sys file which is found *ONLY* on the win-xp *PROFESSIONAL* disk in the I386 directory.
    Would it be possible for someone to locate and send me this file please?
    If you can help pm me and I will send you my email address.
  2. DaveP
    DaveP
    I can send it to you
    Dave
  3. Stellavision
    Stellavision
    Apr 7, 2003
    2,190
    Southsea, UK
    +76
    Thanks Dave, you're a star!:thumbsup:
  4. nwgarratt
    nwgarratt
    May 5, 2002
    26,325
    +2,836
  5. Stellavision
    Stellavision
    Apr 7, 2003
    2,190
    Southsea, UK
    +76
    Tried that last night. When you click download file you get an error saying "We cannot process this transaction because there is a problem with the PayPal email address supplied by the seller...."
  6. nwgarratt
    nwgarratt
    May 5, 2002
    26,325
    +2,836
    I just tried it and got the same. What has Paypal got to do with it?
  7. sholao
    sholao
    Barrie,
    Did you get your MCE remote to work with Media Portal?
  8. DaveP
    DaveP
    You have to pay (using Paypal) in order to download the file!
    To think I gave it away free :suicide:
    Dave
  9. Stellavision
    Stellavision
    Apr 7, 2003
    2,190
    Southsea, UK
    +76
    I have got my MCE remote fully working with Meedia Portal and Meedio, and I can even turn my pc off with it.
    Dave, I'm sure you felt much better for doing a good deed to a forum member.;)
    However, none of the files you sent me were any good anyway. In the end I discovered that I needed I particular version of the irbus.inf file which I managed to download from the peer to peer network.
  10. callagga
    callagga
    Could someone indicate where to download a copy of the driver (for a MCE 2005 remote) please?
    [I have windows XP *HOME* & want to get it working with GB-PVR]
    Tks
  11. Hacker X-13
    Hacker X-13
    I have win-XP Pro and can't find any irbus files in the disk...
    I already DLd the irbus.inf by searching on Google.
    HOWEVER, I can not find the .sys file anywhere... INCLUDING THE INSTALL DISK (compressed or not).
    could someone please send me the files.
    Thanks in advance
    X-13
  12. Singh400
    Singh400
    Feb 21, 2006
    17,840
    Earth
    +3,379
    You aren't looking very hard. It's on my install disk.
    Code:
    [SIZE="3"]25,486 irbus.sy_[/SIZE]
    Thats in the compressed format.
    Code:
    [SIZE="3"]40,832 irbus.sys[/SIZE]
    Thats when I extract it from the compressed file.
  13. Hacker X-13
    Hacker X-13
    Ok so why do I have to point the search to the exact file!?
    any way, as I have stated before I am running Windows XP pro edition. I think some versions no matter how much you patch them will not use the remote... I am trying to get the remote that came with the WinTV-PVR USB adapter to work on my pc. I'm about to give up but not before I build my own receiver and test it. if anyone can help me figure out what's missing I would appreciate it.:lease:
    thanks in advance
    X-13
    PS, I have :rtfm: and it said it should work... but it doesn't.
  14. sonicflood
    sonicflood
    Jul 3, 2009
    2
    I know that this thread is a bit old but I've just resolved the problem with the onboard eHome Infrared Transceiver on my Sony Vaio VGX-XL100 Media Centre and thought that the information could be helpful to someone else.
    My hard drive with Windows Media Centre OS crashed so I swopped it with my laptop's Windows XP Home Edition SP3 hard drive.
    Consequently, I lost the use of the Infrared Transceiver because the required files are not in SP3.
    Windows would not allow me to install XP Update 2 for IR (KB912024) because SP3 was installed.
    The article at the following link gives a general explanation of the problem:
    eHome Infrared Receiver not recognized by Windows XP at it.megocollector.com
    I found the irbus.inf on my other laptop with Windows XP Professional.
    I also copied irbus.PNF for good measure (though I'm not sure whether this file was required).
    I was then asked for the irbus.sys file (after installing irbus.inf) which I searched for in XP Pro and subsequently extracted to the (hidden) INF folder on the media centre.
    The result after a week of lack sleep trying to find a solution: I can now use my Sony Media Centre remote control (RM-MCE10EP) and Harmony One to operate both Windows Media Player and XBMC. :clap:
