IR7243W and TM13
milanlad
Has anyone experienced any compatibilty or interference issues if both, an IR7243W and a TM13, are in operation on the same house code?
I'm having problems diming a lamp module when both are plugged in?
simon1
Established Member
The IR7243 can be very fussy. Try moving either/both this and the TM13 to different sockets.
I had problems when using these two on the same double gang socket - moved the TM13 to another socket, and have had no probs since.
milanlad
I'm having trouble with the IR7243 even when both units are in different rooms or floors.
simon1
Established Member
Isn't there different versions of the IR7243 - 1 house code and ALL house codes?
Perhaps this is the problem.
milanlad
yes there is, but i.m setting both units to house code A. Problem is that they seem to interfere with each other.
does anyone know if these rf units should work if used in the same home, and/or on the same house code.
Sony A84L/A80L BRAVIA XR OLED TV Review - COMPARED to LG C3, Samsung QD-OLED & LG G3
Back
