onelife2000
I am starting a LED lighting project. I am going to edge light Frosted glass panels.
The LED lights are going to be embedded in a recess in the handrail which the glass slots into
I have all the lighting kit
4 x 5 m LED's - 5050 - 300leds Per M -
4 x 96W transformers
1 x RF controllers (+backups)
3 x Amps etc.
Connectors
What I really want to do is wire them up so they come on when someone walks up or down the stairs for say 1 minute afterwards.
So my questions are:
1. Can anyone recommend either..
A timed Pressure pad?
IR sensor with a tight beam?
timer for this?
So when someone steps on either the top or bottom step it will light the lot?
2. I need to work out some sort of circuit for this lot too - If anyone could help that would be great - it's pretty simple - just know that there is some crossover with dual switching that I would probably get wrong
I am a 3d artist by trade so have knocked up some render images of what it will look like.
3 x Amps etc.
Connectors
timer for this?
