IR remote codes
Discussion in 'Home Cinema Control & Remote Controls' started by Digicasta, Feb 7, 2009.
  1. Digicasta
    Digicasta
    Feb 7, 2009
    30
    11
    Surrey
    Dose anyone know where i can find IR codes for remote controls? I have a peice of crap inovix DVD player
  2. Adamh4
    Adamh4
    Jun 20, 2006
    129
    3
    Paignton
    +20
    What learning remote are you using?
    The largest database for IR codes is Remote Central.
    I have never heard of your DVD player make, It may be a rebadged model, and use the same IR codes as other more popular models, alternatively you may be able to learn the codes from the original remote, but again depends what sort of universal remote your using.
    Post back, Adam.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    I think the Logitech database is actually much bigger but you do need a HArmony to access the codes.
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,731
    Somewhere in South Yorkshire
    +6,306
    Moved to Remote Controls >>>
  5. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,577
    Edinburgh
    +1,269
    I suspect you will have to learn the commands manually from the original remote control for the unit as I cannot find any reference to this brand on Remote Central, the Philips Pronto Pro database or the Nevo database.
