IR relays, 2-Way ?
Discussion in 'Home Cinema Control & Remote Controls' started by iwatkins, Mar 16, 2003.
  1. iwatkins
    iwatkins
    Hi All,
    I'm currently building my own AV rack to put all the gear in. Initially it was going to be open fronted, but pressure from the missus means I may be using wooden or opaque glass doors.
    Anyway, so I need an IR Relay that will pass any incoming IR signals into the rack to the equipment.
    However, my amp also sends IR signals back to the remote so I'm looking for an IR relay that is 2-way.
    Anybody ?
    If it comes down to it, I could just use two of them, one for incoming and one for outgoing.
    In addition, can anyone point me in the direction of the better IR relays. Especially those that come in kit form. As I am building the whole rack from scratch, I don't really need any fancy cases. Maybe there is a DIY kit out there ?
    Thanks in advance for any advice.
    Ian
