D
Deleted member 161415
I'm looking for an IR Receiver which I can connect upto using the
Brown & Brown / White Wires and
Blue & Blue / White
Can anybody recommend such I item.
The nearest thing I have found (despite an extensive search - although searching is not that easy when your not 100% sure what your looking) for is a Opus Keypad at £130 - But I only want the IR receiver and, I would have thought £10 - £20 would find such a thing, or, even less if I can find one which I can solder to the Cat5e cable myself.
Many many thanks
Mark
Blue & Blue / White
Many many thanks
Mark
