IR overload on Pioneer plasma?
Discussion in 'Plasma TVs' started by Kaz, Jul 26, 2005.
  1. Kaz
    Kaz
    Anyone heard of Pio's getting buffer overun in the Infra red input (so to speak), I think mine's suffering from the use of my Pronto.
    Is there anyway to clear down the commands it's got stuck on?
    I recently was without my Pio 43MXE-1 for a couple of weeks whilst the local warranty doobries tried to get parts out of Pio.
    This was because it had stopped responding to IR commands.
    In the end they said it had been down to a dry solder joint, but had said it might be to do with using a pronto and the IR firmware getting its nickers in a twist. Now I'm getting the same fault again.
