ir mains switch? all seem to be rf
Discussion in 'Smart Home, Climate Control & Security Forum' started by spook, Dec 14, 2004.
  1. spook
    spook
    May 18, 2004
    157
    Hi all, anyone know of a UK mains switch controlled by infra red rather than the usual radio rf control?
    cheers, Spook
  2. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,648
    UK
    +112
    B&Q have some at the moment that they are selling as remote christmas tree light power adapters - these are just IR power adapters...have a look in B&Q.
    Otherwise I remember seeing a few places on the web that do them...try a google...
    JJ
  3. mambojambo
    mambojambo
    Dec 23, 2004
    141
    +3
    all i could get from B&Q were rf ones
    i thought it was IR till i got it home but it wasnt:(does the job though just means another remote:(
  4. timothy jones
    timothy jones
    Try Varilight dimmer. If you tap when it's on, it will turn right off. Although, when it's off and you tap it, it will dim up (not turn on).
    Dunno if this will work for you, but check it out.
    Timothy
  5. SimonO
    SimonO
    Nov 4, 2002
    3,193
    71
    Hertfordshire
    +64
    You can do this with X-10... Try letsautomate.com
