IR input
Discussion in 'Desktop & Laptop Computers Forum' started by richjthorpe, Aug 22, 2005.
  1. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Hi all,
    I have a Keene IR extender that sends IR signals to wherever you've hidden your AV stuff. Is there a PC card/USB device that can take IR signals through a jack ?
    Richie.
  2. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    DOn't know why you would want one but they have them on ebay, try searchign for USB Infra Red..
  3. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Should have said really. I'm planning on a HTPC that will be hidden away, either in a cupboard or behind a wall. As I've already got an extender, I want to connect the booster box of the extender to an input on the PC to control it.
    Thanks, I'll take a look on ebay.
    Richie.
  4. OneEleven
    OneEleven
    Your motherboard might also have an IR header - you could input through this
  5. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    What a good idea. Haven't bought the Mobo yet so I'll get looking.
    Thanks.
  6. andrew1810
    andrew1810
    Apr 4, 2004
    1,179
    North East
    +55
    This should do what you want, has a reasonably long wire as well:
    http://www.usbuirt.com/overview.htm
    I use mine the other way around (PC controlling STB), but it says it works the other way
  7. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    I use one of these usb ir receivers from http://www.gibbsdesign.co.uk/, its very good and is fully compatible with girder, nice and cheap too.
  8. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Hi guys,
    Thanks for the replies, but all of the options have an IR receiver which I already have. If I was to get one of these, I would have to get another emitter from the distribution amp to the IR detector for the PC.
    The mobo I'm looking at doesn't have an IR header, is there a specificmake that do IR headers, I'm looking at a gigabyte mobo.
    Richie.
  9. Xelon
    Xelon
    Nov 16, 2004
    391
    +53
    Are you planning on using MCE 2005 with youre HTPC? If so the MS Remote and receiver (£25) would be required, mine came with an extender too, and plugs into a USB port, my HTPC is hidden with just the IR receiver on show. I have have the MSI K8N Diamond Dualnet Mainboard as it has integrated Bluetooth (for the MS Desktop Elite BT) and Wi-Fi, also has SB Live 24bit DD sound, very good board for HTPC use as everything is integrated.
  10. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Not specifically looking at MCE. I'm going to try out a product called jriver first, seems to hold together well and as been around for a while.
    http://www.jrmediacenter.com/
    Richie.
