amardilo
My Xbox One is sometimes having a little trouble changing the channel of my set top box (my TV and AV Receiver are fine), sometimes it misses numbers. I think this is down to the Kinect not being able to get it's IR baster to not always send the inputs to the set top box.
I think getting an IR extension cable might help but I don't really want to spend the money if I they don't really help. Anyone used one with the Xbox One before and can anyone recommend a low profile/small one (looking at some Xbox One support documentation any IR extension cable with a 3.5mm connection should do just fine)?
Also if I plug one in will that stop my Kinect from acting as an IR Blaster too, as my TV and AV Receiver work fine I would like it to continue to function as normal although as it sometimes registers with my set top box would that mean that it would send the same input down both the Kinect and IR extension cable possibly causing the input to be registered twice?
