IR extender - help please!!!
roi354
Sorry if this is in the wrong forum but I can't seem to get my harmony IR extender working.
The main problem is I don't know what plugs into where :rolleyes: :D
I've got a tiny transmitter/receiver (don't know which!!!) with a clear LED thingy on the end;
a slightly larger box with a red LED on it and;
a third box with a wide range window on the front.
Now i've got IR in (x1), std out (x4) and high out (x1) on the main unit but what goes where :confused:
Any help greatly appreciated :lease:
BrianC
I guessing here based on my Xantech remote extender but the larger windowed box should be the receiver and plugged into the IR in. The smallest one should be a standard IR emitter and plugged into one of the 4 standard outputs. The middle sized one could be a high power emitter but I would test it with a standard output first - the high output should be the only socket to actually blow components if you get it wrong.
Does the box itself have a power supply? My Xantech gear doesn't work unless its mains adapter is plugged in.
Panasonic HZ2000 OLED TV Review: The best OLED for movie viewing in 2020
