IR Codes Bug in DV88 Plus?
Discussion in 'Arcam Owners' Forum' started by RaceTripper, Jan 27, 2004.
Tags:
  1. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    I have a Arcam DV88 Plus with v4.00 firmware (U.S. model).
    The IR codes for Setup and Status are 25-74 and 25-75 respectively.
    I've noticed that sometimes when I fire the Status code with a remote, the player goes into setup. It happens with the CR-80 remote, but also my Home Theater Master MX-700.
    On the CR-80 the buttons for Status and Setup are right next to each other so I thought I was accidently pressing both. Then I was careful not to when learning those buttons to the MX-700. Same deal.
    So I generated the IR learned code hex directly from the IR codes using a IR hex generation tool. I've used the same tool to generate learned IR code for all the DV88 Plus and AVR200 commands, so I know it works reliably otherwise. But the point is I've taken fat-fingering the Status/Setup buttons out of the equation.
    But I still get the same behavior: pressing Status sometimes also sends the player to Setup mode. I'm now convinced this is a DV88 Plus bug.
    Can anyone shed some light on this please?
    Dean
  2. robocop
    robocop
    Oct 16, 2000
    648
    Old Detroit a.k.a. Chippenham. Wilts
    +23
    I have the same problem on my DV27+ and my previous DV88+.
    I originally thought this was due to the fact that I am using a Pronto as my remote.
    However, you having the same problem with the Arcam remote has dispelled that idea.
    I have recently upgraded from 4.12.0 (which had the problem) to 4.18.0
    There a some interesting additions/fixed bugs, but I haven't tried to replicate the above problem. I will let you know how I get on, but suggest you have the latest software installed; it's worthwhile.
  3. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    Kevin,
    What's in v4.12/18 that's not in 4.00?
    I don't want to pull my gear and drive it to the dealer unless it's a worthwhile effort.
    Thanks,
    Dean
  4. robocop
    robocop
    Oct 16, 2000
    648
    +23
    Checkout the 2 threads below regarding FMJ firmware and software.
    Sorry I can't supply the links as I'm using a cellular to write this :D
  5. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    Thanks Kevin,
    I'll see if my dealer has 4.18. I'm in the states, so I may need to wait longer for it than you folks.
    Dean
