Hello
Is there any app available to use IPTV on hisense?
Thank you for your help
Salomao
Even though it says Samsung, I was able to download this in the apps store, and it works fine on my Hisense.[emoji16]Hi mate, try this.
Samsung Smart TV
If you put a search for siptv into the Hisense app search, you should be able to see it.But how can I install it?
Sorry, I am confused [emoji37]Even though it says Samsung, I was able to download this in the apps store, and it works fine on my Hisense.[emoji16]
I have already done it. There are no results.If you put a search for siptv into the Hisense app search, you should be able to see it.
Sorry, I managed to find a in the Hisense store.Sorry, I am confused [emoji37]
How can I access any other store than the Hisense own store?
I cant find any other way to install apps but on hisense store and there I can't find any iptv apps [emoji21] [emoji22]
Not in 65n5750! Damn!!Sorry, I managed to find a in the Hisense store.
It is there.
Are you in UK.Not in 65n5750! Damn!!
No. PortugalAre you in UK.
That might be the problem.No. Portugal
Smart IPTV is no longer available in Italian Samsung Apps StoreThat might be the problem.
I'm using it on the 43" M3000.
So yours should have it
Try going to the siptv.eu website, it might help.
The question, once again, is: How to access Samsung store. The only store I can access in my television is the Hisense storeSmart IPTV is no longer available in Italian Samsung Apps Store
Samsung (not App developer!) has removed Smart IPTV application from Italian Samsung Apps Store as a "measure" to fight piracy. Please check Samsung guidefor a possible workaround to install the App.
I found this on the siptv website. Again, I know it mentions Samsung, but it might explain why you cannot see the app in the store. Portugal might have asked Hisense to remove it.
Good luck
The app is supposed to be for only Samsung, LG TV's.The question, once again, is: How to access Samsung store. The only store I can access in my television is the Hisense store
I know SMART IPTV since I use it in a Samsung TV I have.The app is supposed to be for only Samsung, LG TV's.
But it does work with other makes of TV.
I managed to find the app on my Hisense smart TV,
In the Hisense App store.
You are either making a mistake whilst searching for
The app. Or for some reason it is no longer available.
I actually sent the people responsible for the app a question.
Once installed, it's free for 7 days.
Then it costs €5 to keep. I went to purchase, and it said that
Because my TV was a Hisense, the app was still in Beta mode concerning this TV, so it was free to use.
You must be blindI know SMART IPTV since I use it in a Samsung TV I have.
I just cant find that app in hisense store or any other iptv app. That's my problem.
I wich I was!You must be blind
I'm sorry mate, but not being a android TV could mean your shafted.I wich I was!
I have searched the store several times...
Later I will send you a photo too
Please note that this model (65n5750) is not an Android TV
Thats why, beeing a recent hi tech SMART TV, it should include an iptv app. I don't understand why notI'm sorry mate, but not being a android TV could mean your shafted.
I agree, it's mental that it isn't there.Thats why, beeing a recent hi tech SMART TV, it should include an iptv app. I don't understand why not
My own streams, for exemplepiracy, piracy and piracy. To easy to add illegal content. What legit content is there to add to it that isn't available on the genuine streaming services?
None of them are available in hisense marketOTT PLAYER \ SMARTIPTV
