Ipods !!
Discussion in 'Headphones, Earphones & Portable Music' started by oggy, Jun 22, 2005.
Tags:
  1. oggy
    oggy
    Feb 5, 2002
    236
    Turriff
    +6
    Hi there being driven up the wall with ipods 5 in the family 1 shuffle,1 1st gen ipod,3 minis...... how on earth do you use 1 computer to fill up 5 ipods with music we were using 3 computers when we had 3 ipods couple at work 1 at home no problems but when you come to connect up more than 1 to 1 computer the probs start...replacing play lists ,not recognising ipods etc etc any help on the subject would be immensley welcome. After a search on here have spotted a potential fix :suicide:
  2. mick's cat
    mick's cat
    The best way to service more than one iPod on a single computer is to set up multiple user accounts. Do this within the OS. Each user logs in (with a password, if you want) as they wish to use the computer. That way, every iPod has its own Library within iTunes, totally separate from all the others. The music, on the other hand, can be still shared by users across the accounts, so you don't need to re-rip any music.
    However, you can also do it on a single user account by turning off automatic syncing within iTunes. This way though, each iPod has to be synced manually - ie, dragging music on and off.
  3. KeanosMagicHat
    KeanosMagicHat
    Feb 7, 2005
    4,551
    England, UK.
    +554
    Candidate for addition to the FAQ list?
    Saw this one asked a couple of days ago too and seems a useful tip.
  4. Steve Rollings
    Steve Rollings
