iPod Volume Booster
Discussion in 'Headphones, Earphones & Portable Music' started by G a f f e r, Dec 30, 2004.
Tags:
  1. G a f f e r
    G a f f e r
    Dec 31, 2003
    3,017
    U.K.
    +628
    To get around the EU 100dB limit for european iPod's, some of you may have installed this software that is meant to "reset" the iPod firmware back to US settings of max 102-103 dB output.
    Despite what the readme says about this software, it doesn't seem to alter the iPod firmware to lift the dB cap to above 100dB. All it does is change all the tracks to 125%ish percent wrt the track volumes (highlight a track in itunes and press command-i, then go into the options tab - all this software does is alter the tracks volume setting).
    Is there any software that alters the iPod's firmware rather than alter the individual song settings?
    thanx 4 any info
  2. mick's cat
    mick's cat
    Hmm, I use my iPod with my Mac, and I know that there are some utilities that just adjust the track volumes as you say, which is pretty useless. There is at least one utility for the Mac that correctly adjusts the firmware though, so I guess there will be some that do the same for an iPod on Windows (assuming that's what you're using).
    FWIW, the Mac tool I use is goPod:
    http://gopod.free-go.net/index_en.htm
    It works a treat.
    Any time you update the iPod's firmware (for Apple updates) you obviously then have to reapply the patch.
  3. G a f f e r
    G a f f e r
    Dec 31, 2003
    3,017
    U.K.
    +628
    Me, use windows?......with My reputation... :D
    Seriously though, definitely Mac (too use to system stability to devolve back to Windows). Thanx for the link, I'll give them a go...
  4. mick's cat
    mick's cat
    Well, I'm a noobie here, so I don't know your reputation... ;)
    Anyway, I reckon you'll find goPod does the trick nicely. I can now listen to my iPod while I mow the lawn or sit beside the missus without any of that background noise clutter getting in the way of the music. :clown:
  5. LinkinRuss
    LinkinRuss
    Dec 4, 2004
    178
    i hear a program called imod also works, but hasnt been tested on 4th gen yet
  6. w3dal
    w3dal
    Aug 4, 2002
    5,050
    Chelmsford, Essex
    +587
    I have just downloaded the windows version.
    How does this program exactly work. Are there any settings i need to change??
    Its for a mini ipod that i bought my other half for christmas
    Dal
  7. mick's cat
    mick's cat
    Well, with the Mac version you just connect up the iPod, launch the app and click Go. Then goPod does its stuff and reports back that the job's done. There are no settings as it's just a simple switch of certain bits in the firmware that tell the iPod to work at full volume level instead of EU-crippled volume level. I would think it's the same with the Windows (and Linux) version. Dead simple.
    Oh, wait, I forgot - turn the volume down next time you listen...
  8. w3dal
    w3dal
    Aug 4, 2002
    5,050
    Chelmsford, Essex
    +587
    Thanks allot mate i ran the op as im at work and it says waiting for an ipod.
    So ill install that when i get home and try it on the girlfriends ipod. Although she has not commented that it is quiet. I think it is a little (could be going deaf i suppose)
    Dal
    :thumbsup:
  9. G a f f e r
    G a f f e r
    Dec 31, 2003
    3,017
    U.K.
    +628
    Big THANX to Mick's Cat.......works very well
  10. w3dal
    w3dal
    Aug 4, 2002
    5,050
    Chelmsford, Essex
    +587
    yeah just done it and what a difference.
    Are there any decent headphones for about £25.00 that i should be thinking about getting.
    I cant believe how easy it was todo
    Dal
  11. Mark R
    Mark R
    I have just downloaded this programme for windows and tried to run it on my 4G 20gb ipod. It says that the pod is not recognised - I have tried both USB and firewire connections but neither works.
    I know that my PC recognises the ipod as itunes works with both USB and firewire.
    Anyone know what I'm doing wrong?
    Mark
  12. ericlered
    ericlered
    hi mark im guessing that you have to plug your ipod in 1st and have the circular icon flashing "do not disconnect" when you run the gopod program
    thats what i do with eupod and it then "finds" the ipod drive
  13. Mark R
    Mark R
    Cheers.
    Have done this and it worked - it now says that the ipod is uncapped. However I'm not sure that I can notice any difference in the level of sound. Am I going mad?
    Have closed the programme down and gone back into it and it still says uncapped.
    Is the volume difference that noticable>
  14. ericlered
    ericlered
    Hi Mark
    I have never used gopod so i couldnt tell ya
    eupod makes a hell of a difference to mine though so u might like to go to the official eupod site and check that out, be careful to read about resync tho if u use it
  15. mick's cat
    mick's cat
    Yes it should be noticeable. Maybe you're just going deaf not mad... :D
    You can go back to capped if you want to confirm which it is (mad or deaf), by reapplying Apple's latest firmware. Then just reapply goPod to uncap again.
  16. Waser
    Waser
    Mar 1, 2004
    1,043
    Purley, Surrey
    +75
    If you have a windows PC then iMod is the program of choice on the www.ipodlounge.com forums. I don't have the link for the app handy but you can do a search at those forums and find plenty of threads. it has been proven to work on the 4G iPods. Apprently it improves the sound as well as removing the limiter.
    I haven't used it on my 4G iPod yet but I plan on doing it this weekend. I find the iPod max volume loud enough, I'm more interested in the sound improvement.
  17. G a f f e r
    G a f f e r
    Dec 31, 2003
    3,017
    U.K.
    +628
    only gopod and imod modify the firmaware to uncap the volume limit of the ipod.
    the others (like eupod) just alter the tracks volume settings and do not alter the firmware (despite what their readmes say)
    don't use EUpod/ipodvolumebooster etc etc,
    use imod or gopod
  18. w3dal
    w3dal
    Aug 4, 2002
    5,050
    Chelmsford, Essex
    +587
    i cant tell the difference big time and so can the other half. Infact i can hear her using it in the bedroom now as i type this
    Dal
  19. geewhizz
    geewhizz
    Jan 2, 2005
    2,458
    +89
    I done it the other day and i noticed a big difference.
    the only downside is with the extra volume is,
    I can now tell how rubbish the earphones are,
    so will go and get new ones. :suicide:
    fanx alot
  20. davehk
    davehk
    Oct 17, 2003
    711
    28
    London
    +45
    I used GoPod on my new 4G 40Gb unit last night and noticed no difference at all. Also, imod does not appear on the ipod lounge forum anymore (well I couldn't find it, anyway)
  21. davehk
    davehk
    Oct 17, 2003
    711
    28
    London
    +45
    But, having not used my Ipod for 48 hours, it went into cold-start mode and now the volume cap has been lifted!
    Now I expect I'll get the ******* disk error next time I hook up to Itunes and have to run Chkdsk on it!
