IPOD usb problems
Discussion in 'Headphones, Earphones & Portable Music' started by Laingy, Mar 24, 2006.
Tags:
  1. Laingy
    Laingy
    Just bought a USB for an ipod (previously used fire wire), as I have just bought a new laptop. However the PC did not recognise the ipod connected via this method - has anyone had similar problems as this?
    regards
  2. James Ferrier
    James Ferrier
    Oct 11, 2005
    200
    Brighton
    +6
    make sure you've install the ipod software on the laptop correctly.
    you can get the latest version from the apple site and also ipod updater software, i've found that can resolve any problems.
  3. Laingy
    Laingy
    thanks, good idea
