Ipod update
Discussion in 'Headphones, Earphones & Portable Music' started by DustySox, Jan 15, 2005.
Tags:
  1. DustySox
    DustySox
    Aug 25, 2004
    535
    Wokingham
    +10
    Is there a way to set itunes to only update latest ripped cd's? As it takes ages to update nearly all 3000 songs I have, and then boosting volume as well nearly takes 50 mins, and exhausting battery on my Ipod.
    Kind regards
    Darren
  2. Starvald
    Starvald
    Jan 6, 2005
    55
    Liverpool
    Hmm that's weird. Mine just downloads the latest songs that I've ripped/downloaded and placed in my music directory.
    You can turn off automatic update, but you'll have to manually move songs onto it within itunes.
    As for boosting volume, I used a program to remove the EU restriction and enable the volume to go higher. Couldn't be bothered with normalising or increasing the volume of everything.
  3. DustySox
    DustySox
    Aug 25, 2004
    535
    Wokingham
    +10
    Hi Starvald
    Thanks for getting back to me. What volume software did you use to remove EU restriction?
    What settings have got in Itunes that only updates latest ripped cd's?
    Darren
  4. jinky32
    jinky32
    Oct 17, 2004
    346
    +6
    the software is EuPod by a guy called Espen. Put it in Google and you'll go straight there.
  5. probedb
    probedb
    Aug 20, 2003
    2,654
    Sheffield
    +180
    Also goPod as well, removes the 100db limit on EU iPods !
  6. popester_uk
    popester_uk
    Dec 10, 2002
    316
    Brighton, East Sussex
    +9
    if you set manual updates, you can then select which playlists it will automatically update.
    it's in the ipod preferences on iTunes
    kelvin
  7. probedb
    probedb
    Aug 20, 2003
    2,654
    Sheffield
    +180
    Ahh but that doesn't include the on-the-go playlist.
    iTunes *always* copies the existing one to a new list i.e. On-The-Go-1 then wipes it ! Does anyone have any idea why as this has meant I stopped using iTunes ??
  8. w3dal
    w3dal
    Aug 4, 2002
    5,046
    Chelmsford, Essex
    +585
    This is the one i used. Really easy to use and works a treat! :thumbsup:
    Dal
