Ipod to HiFi connection?
Discussion in 'Headphones, Earphones & Portable Music' started by JimDav, Mar 20, 2006.
Tags:
  1. JimDav
    JimDav
    Mar 14, 2006
    15
    What is the best method of connecting an Ipod to a hifi system. Can you get a decent sound quality using a '3.5mm jack to 2x RCA' cable, or are there docking cables available that use the Ipod's dock connector?
  2. kevH
    kevH
    Oct 11, 2004
    833
    Live Leeds Work Chesterfield
    +37
    The best method ive found is to use the universal ipod dock with an AV cable through to the HiFi / TV. I also bought the small apple ipod remote and this seems to work perfectly. I tried just an 3.5mm jack to Rca cable at first but it just didnt seem as "nice" as the dock does.:smashin:
    I bought the dock and remote from Apple but the cable i bought from an on line retailer for only £6 and it works very well.
    There are cables only that use the dock connection but i havent tried this method as i find the Universal dock far better along with the remote facility.
  3. PJTX100
    PJTX100
    Dec 21, 2004
    8,143
    +564
    As KevH says, if you want it to look snazzy and have remote control capability then the dock is the way to go. However if you just want to link to the HiFi then purchase a decent dock to phono lead.
    I've only tried the headphone jack to phono so far which sounds pretty good but I'm sure the proper line-out feed is superior.
  4. mattals
    mattals
    How would you use the propper line out, what cables would i need !!
  5. JimDav
    JimDav
    Mar 14, 2006
    15
    Am considering the Kensington dock as this has AC adaptor & remote 'in the box' rather than buying separate as, it seems, you have to do with the Apple universal dock.
    One thing puzzles me though.... The 'line out' on these docks is a 3.5mm jack, is this not just a 'port-through' of the headphone jack? It should be just as good, then, to just use a 3.5mm to RCA cable sraight from the Ipod as long as you don't need charging or remote control.
  6. PJTX100
    PJTX100
    Dec 21, 2004
    8,143
    +564
    No, it will be a port through of the line-out connectors that are part of the dock connection point at the bottom if the iPod. Hence it should be superior to the headphone jack because, among other things, it will bypass the volume control circuitry.
  7. PJTX100
    PJTX100
    Dec 21, 2004
    8,143
    +564
  8. Davy
    Davy
    Apr 25, 2005
    376
    5
    Warwickshire
    +34
    I use a 'Monster' cable, purchased for around £20 for a 2 metre length, on the net. Connect to iPod headphone socket and amp - works fine for me.
  9. PJTX100
    PJTX100
    Dec 21, 2004
    8,143
    +564
    I've been impressed by the output from the headphone socket too, but the line out via the dock connector is supposed to be better still.
  10. Ipmack
    Ipmack
    Just to be michevious, you could always get an XBox 360.
    Just connect the ipod to the xbox via the standard USB cable, then optical out to the amp and ... well sound quality is pretty good (although currently through my Mordaunt short genies - the KEF Q60s are in the attic).
    Additionally you get to save the money you would have spent on a remote and get to use the Xbox controller (I'd recommend the wireless one)
  11. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,267
    +68
    There are some oddities about the Universal Dock connection that I've been looking at that means it may not be the best way to connect. At the simplest level you're looking at a thinner sound. If you want to pick extreme nits the sound quality may be slightly off as well.
    I can actually get a slightly better signal out of the headphone out when set a bit off full blast or the analog line out (the Universal dock takes a digital feed fromthe iPod and squirts it though it's own DAC-chip to enable volume control via the remote... but this seems to be a bit stunted for some reason). Unless you need volume control, you're better off using the older docks if they fit (haven't tried... got rid of them all!) or a Sendstation Pocketdock.
  12. JonHarper
    JonHarper
    Nov 26, 2002
    22
    London
    It looks like you can get some pretty good integration with the docks from Griffin http://www.griffintechnology.com/products/tunecenter/index.php and DLO http://www.dlo.com/products/homedoc_dx_Prod.tpl
    I think they're both new products and I'd be interesetd in reading a comparison between them. Griffin appear to be using the iPod screens and DLO have used their own.
    If you just want mp3's on your HiFi and aren't worried about using your iPod then you could use Freecom's network MediaPlayer http://www.freecom.com/ecproduct_detail.asp?ID=2594&CatID=8060&sCatID=80604&ssCatID=80604
    Jon
  13. KeithO
    KeithO
    May 28, 2003
    1,435
    63
    Erding, Bavaria
    +214
  14. PJTX100
    PJTX100
    Dec 21, 2004
    8,143
    +564
  15. dilsher
    dilsher
    The pin-dock to RCA cable option is without doubt the best possible connection for quality with its optimal signal transfer, transparency and optimised volume capability. The Y-leads phono docking option is second best but loses volume and dynamics whilst the headphone phono output option is the worst.
  16. JonHarper
    JonHarper
    Nov 26, 2002
    22
    London
  17. KeithO
    KeithO
    May 28, 2003
    1,435
    63
    Erding, Bavaria
    +214
    If you click on "More Images" and then take a look at the Full Size pic of the connection panel at the back, you'll see it just above the RS-232 connector, clearly marked iPod. It looks a bit like a big s-video socket, but with more plugs. The amp comes with the relevant cable.
    And you're right - it is a monster :D
  18. dilsher
    dilsher
    That is one helluva amp mate - cool! More and more manufacturers are inlcuding an Ipod input.
    Dil
  19. Confused40
    Confused40
    Hi I have a 30gb ipod, a Sony DAVS880 Home Cinema System. I bought and Ipod AV Cable today hoping to play my music round this Sony but despite plugging in the coloured leads nothing is happening.
    Anyone help me :lease:
  20. sjackson
    sjackson
    Jan 8, 2006
    2,189
    116
    Ireland
    +539
    TuneCenter on eBay for £50
    http://cgi.ebay.co.uk/Griffin-TuneCenter-Home-Media-Center-for-iPod_W0QQitemZ8767886698QQcategoryZ25446QQcmdZViewItem
  21. bazlington
    bazlington
    May 22, 2006
    37
    Does anyone know when the Griffin Tunecenter is going to be released for general sale?
    Chris
  22. cheeseywang
    cheeseywang
    Jan 26, 2003
    218
    over the blue moon
    I have the Kensington Stereo dock and I'm very pleased with it. Cost me £44 from Amazon which is considerably cheaper than the Apple universal dock and remote.
