iPod suddenly not playing large number of songs - help
Scapegoat
iPod is now just skipping over a number of songs (both purchased and imported).
Have re-connected up to the PC for an update but no improvement.
iPod library is 17gb, but when you open the iPod in iTunes - the bottom bar says 17gb, but the graphical bar above it shows 11gB.
Any ideas on how to solve? Fairly urgent as off to the Carling festival soon and want it to work.
Thanks in anticipation
stevelup
Assuming all the content is still in your iTunes library on the PC, and still plays OK from there, I'd do the following:-
Run the iPod updater and select the option to completely wipe the iPod, then let it sync with iTunes again.
That should solve your problem.
Steve
jason44mag
I agree with steve, but one thing i have had a few probs yesterday with itunes not writing to the ipod so i pulled the ipod out without ejecting it first via itunes (i manually update playlists so need to eject after use).
This is a major pain in the ar**, the ipod then shows error folder and wont do anything !! so you have to reinstall ipod updated and start again. :suicide:
Scapegoat
stevelup said:
Steve
Thanks - can you give an idiots guide to how I get to this i.e. menu paths?
Also I fear 17gb over USB 1.0 might take longer than I have before I need to set off :thumbsdow
Might have to wait until Monday and just swear everytime it refuses to play a song I want :devil:
jason44mag
Hi Scapegoat
The updater is available from http://www.apple.com/support/downloads/ipodupdater20060628.html
Down load this, it does take a while.
when its done make sure itunes isnt running, plug in you ipod then if the updater doesnt start automatically go to your start menu > all programs > ipod updater.
This will bring up a menu to either update your ipod software or restore your ipod go to restore.
This will bring your ipod back to factory settings & hopefully solve your probs :smashin:
Hope this helps
