Ipod scratched screen
Discussion in 'Headphones, Earphones & Portable Music' started by Peter Kendrick, Mar 20, 2006.
Tags:
  1. Peter Kendrick
    Peter Kendrick
    Jan 1, 2005
    65
    My wife bought me a 30gb Video Ipod for my birthday from Dixons taxfree store at East Midlands airport. After opening the box and carefully charging it up/trying it out I noticed scratches on the screen. I have not even taken it out yet and can't believe how easily the screen was damaged. I checked out the Apple website and it looks like this is an Ipod problem. This is not the quality i expected for nearly £200 and from the "reputed"? Apple brand.
  2. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,267
    +68
    Players like the iPod have always scratched easily, but the Video is worst affected because it's totally flat, which reflects light well, and assuming yours is black, shows off scratches better than the white used until now.
    You could raise a ruckus about it back at the shop and exchange it, or you could get a screen protector... or what I use, a clear case. My 30 gigger is pristine due to the case, which doesn't add a lot of bulk but gives it a lot of protection.
  3. Lennyz
    Lennyz
    Jul 27, 2002
    339
    Cheshire
    +13
    extremelydodgy, Which case have you plumped for. It seems to be a minefield when you read reviews on this stuff!
    I am looking to get a 30gig and want to sort out protection before I even get the pod. Just wondering what you use, being as your ipod is still pristine.
    Ta
  4. S//Punk
    S//Punk
    obviously im not extremely ddgy but i have a suggestion for you: www.shieldzone.com in my opinion one of the best screen protectors out there.
  5. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,267
    +68
    I'd suggest the invisibleshield too if you don't need any impact protection. The advantage of the 'skins' as opposed to cases is that the iPod remains dockable. I use the Agent 18 Videoshield at the moment. I'll pick up the Contour cases whenever I can to try them out. I always liked the relatively bulky but protective Showcase because it makes the iPod totally (almost literally) "Throw-into-a-bag-able", and they have finally released one for the 5G.
    Micro Anvika are/should be selling all of the cases you see below.
    http://www.contourcase.com
    http://www.agent18.com
  6. Jammyb
    Jammyb
    Feb 5, 2006
    4,029
    Coventry
    +576
    if it comes down to it you should be able to polish out the scratches on the screen with a little brasso or similar metal wadding type polish, works well on mobile phone screens too.
  7. shahedz
    shahedz
    Apr 26, 2005
    11,063
    +1,951
    i have been trying the brasso method and it doesnt seem to be working for me, any ideas on how to do it properly,
  8. PJTX100
    PJTX100
    Dec 21, 2004
    8,143
    +564
    Apple produce a "goo" specifically to take out scratches. Car wax seems to do the trick though.
  9. kevH
    kevH
    Oct 11, 2004
    833
    Live Leeds Work Chesterfield
    +37
    Just thinking aloud here and maybe im talking absolute b*ll*cks but if brasso works wouldnt something like T-Cut work also ?? Am i right in thinking that t-cut isnt as "aggressive" as brasso ??
    Just pleased i "babied" mine from birth and got a film protector and the Agent 18 Videoshield straight on it , now i only have to rub out all the scratches that the missus seems to collect on her car !!! :thumbsdow
  10. PJTX100
    PJTX100
    Dec 21, 2004
    8,143
    +564
    I likewise was surprised that brasso was mentioned as a good option, I always thought it quite an aggressive option only to use as a last resort. T-cut should be a good option for deeper scratches but normal car wax is a less aggressive form of T-cut.
  11. kevH
    kevH
    Oct 11, 2004
    833
    +37
    So Swarfega isnt a viable option then ??? Just we have loads of that lying around in the bedroom !!!! ;)
  12. morganog
    morganog
    T Cut works great!!
    I do my nano all the time with the stuff then polish up with a bit of turtle wax
    All you need is a good hour or so of rubbing and the scratches are gone
  13. shahedz
    shahedz
    Apr 26, 2005
    11,063
    +1,951
    an hour? my arm would drop off :eek:
