ipod questions
Discussion in 'Headphones, Earphones & Portable Music' started by obi, Dec 3, 2004.
Tags:
  1. obi
    obi
    Nov 29, 2004
    279
    +70
    I am thinking of buying an ipod, just wanted to know a few things:
    a) What does sync mean?
    b) Can I plug it into my car CD stereo?
    Thanks in advance
    obi
  2. GizmoStu
    GizmoStu
    Dec 1, 2004
    38
    London
    +4
    Hello,
    Well, syncing means to synchronise your iPod with iTunes. iTunes is piece of software that you get with the iPod that you use to create a library of your mp3/aac files. It is worth mentioning that the only way to get songs from your computer to your iPod is via iTunes (unless someone has found another way?).
    There is an option whereby every time you run iTunes with your iPod connected, it will ensure that the contents of the iPod reflect whatever is in the library (i.e. "syncing" it). My preference is to keep it turned off as I don't really require that degree of automation. It suits some people though.
    I've not tried to connect my iPod to a car stereo so I'll let someone else answer that question. However, it can be done as I've seen it done first hand.
  3. alancolledge
    alancolledge
    Feb 2, 2004
    518
    Middle England
    +5
    Obi,
    If your car has an auxillary in(maybe a input jack at the front of the unit) you are laughing; .
    If it is like many others then you can either use an FM modulator to send the signal over the radio waves and tune the radio to recieve them, or there are new products where, if compatable, you can attach the Ipod like a CD changer and be able to control it via the head unit. Dension Ice link is one such device.
    I use a modulator for mine and I am not happy, too much noise in the background and the sound is not as dynamic. I will be changing the car soon but may invest in a proper kit then.
  4. obi
    obi
    Nov 29, 2004
    279
    +70
    Cheers for that Gizmostu just wondered what the term Syncing meant. So there is no way that I can use any other Software other than Itunes ti download music onto the ipod?
  5. simon100
    simon100
    Nov 2, 2004
    319
    +11
    You can use MusicMatch, which is basically the same as iTunes. You have to get an iPod plug in from the MM site for this to work. They both have very similar functionality.
  6. ancientgeek
    ancientgeek
    I don't know how practical it is, but you can have iTunes catalogue your music without moving it from where it is managed by some other software. So using iTunes to sync doesn't prevent you using some other software to maintain your music library.
