ipod prob - internet con freezing
Discussion in 'Headphones, Earphones & Portable Music' started by happychappy, Aug 22, 2005.
Tags:
  1. happychappy
    happychappy
    Nov 17, 2003
    333
    londoniumish
    +45
    Hi all
    I have an ipod mini 4gb that freeezes my Tesco broadband connection when itunes searches the cd data base prob manifests as :-
    1, insert CD
    2, CD searches website and starts importing contents to itunes
    3, CD finishes loading and ejects
    4, load in a fresh CD and it will not connect to the data base, in fact broadband connection is frozen. At this point I either have to pull out the USB lead of the modem or restart the PC
    This problem happens everytime that I load in a fresh CD
    points of interest;-
    1, I have spent days on the phone to Tesco and they have not faced this prob before. (we have tried everything just falling short of a windows re-install.)
    2, PC broadband connection runs perfectly - other than the itunes database
    3, I am currently using a USB 1.1 con (I do not have USB 2 input )
    4, I only have a modem and a printer plugged into my USB inputs
    Has anyone any ideas? has anyone else experienced this prob?
  2. pjskel
    pjskel
    Oct 12, 2004
    2,687
    83
    UK
    +122
    It's not an iTunes database - iTunes (like others) connects to CDDB (Gracenotes). Turn off the auto import function. Insert CD, let it access the CDDB, then eject it and try another CD - see if the same thing happens.
    After that, we'll have a bit more of an idea.
  3. happychappy
    happychappy
    Nov 17, 2003
    333
    londoniumish
    +45
    I have turned off the auto import function and loaded 5-6 CD,s successfully - my internet connection is still functioning.
    Looks like we could be onto something here! Fingers crossed
  4. HMHB
    HMHB
    Nov 11, 2001
    26,714
    Nottinghamshire
    +5,470
    Yes I have the auto import turned off. I just have the option set to connect to internet when required and tell it to just display the contents of the CD when inserted.
  5. happychappy
    happychappy
    Nov 17, 2003
    333
    londoniumish
    +45
    Bad news.
    Although I loaded the CD,s into the drive last night I did not import them. This morning I have attempted this and guess what....My connection froze!
    I am beginning to wonder wether I should buy the ipod - firewire lead or perhaps change my usb 1.1 to usb 2.0?
  6. pjskel
    pjskel
    Oct 12, 2004
    2,687
    83
    UK
    +122
    Shouldn't make a difference as the two are not inter-related nor co-dependants.
    Something else is causing the problem, although, I'm wondering if the PC doesn't have enough grunt to multi-task.
    More info on setup, etc.
  7. HMHB
    HMHB
    Nov 11, 2001
    26,714
    Nottinghamshire
    +5,470
    Is there any way your modem can be conneted via ethernet rather than by usb ? I've always found ethernet modems to be far more stable than usb ones.
    You can also get PCI cards for you computer that have a couple of USB2 and a couple of Firewire ports on so you get to use either.
  8. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    37,222
    +6,428
    Firewall?
    Conflicting program open?
  9. IanPM
    IanPM
    Jan 12, 2004
    389
    +6
    I wonder if this is something to do with the USB Bus. If both devices are plugged into the same bus, there might be a hardware level conflict. A cheap USB2 card from ebuyer or dabs might solve the problem.
  10. HMHB
    HMHB
    Nov 11, 2001
    26,714
    Nottinghamshire
    +5,470
    That was the reasoning behind me asking if the modem can be connected via ethernet rather than USB.
  11. cheshire_carper
    cheshire_carper
    Jun 28, 2004
    693
    +83
    USB modems.....yeuck :D
    As the fella states, routing is the way forward!
  12. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    37,222
    +6,428
    Hey, I still use USB to connect everything, and I've never had problems
    But will buy router et al as soon as I get money
  13. happychappy
    happychappy
    Nov 17, 2003
    333
    londoniumish
    +45
    Caught up at work sorry for the delay in my reply:-
    "More info on setup"
    = AMD Athlon XP1700+, 1.48 Ghz 512 ram, 80G harddrive (42 Gig available) Windows XP service pack 2.
    "Firewall?
    Conflicting program open?"
    = Firewall settings checked by Tesco all ok (AVG free version)
    = No other progs open when trying to load cd into itunes.
    It has been mentioned to me before that the USB Modem may well be the problem (Speedtouch 330)
    On reflection I can see how the usb 2/firewire situation will make no difference (I do not have any connection probs with the ipod mini.)
    Thanks for all replys
