E
electron1954
Is this normal?
If I remove the phones from my iPod Photo, the playback usually stops/pauses a few seconds later.
This is problematic when moving with the iPod in your pocket in "hold" mode and the headphone socket spins in the socket and causes a momentary disconnect. This has happened a few times and means I have had to unset "hold", press play and reset "hold".
Is this a "feature" that can be unset in some menu - or is mine faulty?
