ipod photo dock
Discussion in 'Headphones, Earphones & Portable Music' started by kingsize, Mar 30, 2005.
Tags:
  1. kingsize
    kingsize
    Jul 16, 2004
    1,038
    +49
    Stupid Question?
    Want to get an ipod photo. And I want to connect it to my amp.
    Can I buy the ipod photo dock from apple, and simply plug the power cable ( I assume this is supplied with the ipod?) into the dock so that it is mains powered while connected to the amp i.e. not using the battery?
    Does the ipod photo dock accept a power in line as the regular dock seems to?
    Also, what dock/speaker combo would anyone recommend for a bedroom?
    Thanks folks....
  2. HMHB
    HMHB
    Nov 11, 2001
    25,561
    Nottinghamshire
    +3,892
    If it's the same as the normal iPod docking station, you can run it off the mains. You plug the normal end of the cable that normally attaches to the bottom of the iPod to the docking station and then the firewire cable end plugs into a mains adaptor.
