iPod Mini
Discussion in 'Headphones, Earphones & Portable Music' started by petrolhead, Jul 18, 2005.
Tags:
  1. petrolhead
    petrolhead
    Mar 29, 2002
    4,783
    87
    Newcastle
    +116
    Got my new toy
    A couple of questions tho.
    1) How much difference to the volume does GOPOD make?
    2) Can I use ITunes to copy tracks from a CD?
  2. gerbilly
    gerbilly
    Mar 20, 2005
    2,193
    Hamilton
    +94
    Go Pod makes a big difference in volume levels, download it as soon as you can.
    Just put your cd in and I-tunes should automatically start. All you have to do now is press import and your cd will be copied.
    Check which mode you are recording with tough. I use aac 192. :D
    Enjoy your toy.
  3. petrolhead
    petrolhead
    Mar 29, 2002
    4,783
    87
    Newcastle
    +116
    Already had GOPOD but cant seem to notice any difference
  4. ipodstudio
    ipodstudio
    ..try EUPOD.. :D
  5. gerbilly
    gerbilly
    Mar 20, 2005
    2,193
    Hamilton
    +94
    Eu pod doesnt remove the eu cap it artificially increases the volume levels.
    When you download go pod you have to make sure the logo says your i-pod has been uncapped.
    Before i did this, I had it at max when listening to music.
    After I used go-pod I listen between 50-75% volume levels. :smashin:
  6. petrolhead
    petrolhead
    Mar 29, 2002
    4,783
    87
    Newcastle
    +116
    It confirms that it has been un-capped but I can't tell the difference
    Will have another look tonight
    Cheers for the help
  7. gerbilly
    gerbilly
    Mar 20, 2005
    2,193
    Hamilton
    +94
    I take it you are comparing it through your earphones. If not then the volume comes from your amp not the i-pod.
  8. petrolhead
    petrolhead
    Mar 29, 2002
    4,783
    87
    Newcastle
    +116
    Yes thro the ear phones - thats where I assume the improvement will be
