ipod mini connection probs
Discussion in 'Headphones, Earphones & Portable Music' started by phatmattuk, Jun 22, 2005.
Tags:
  1. phatmattuk
    phatmattuk
    just connected my ipod mini via fire wire for 1st time and its asking me to either update or restore, update does not light up so the only option is restore to factory settings ( odd cause its new ) and now i just have do not disconnect flashingon the ipod and none of the ipod symbols in i tunes. any one any ideas plz
    matt ipod virgin
  2. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,236
    +63
    Just choose restore if it's new. But you might like to check that the iPod software you're restoring is the latest one. If in doubt, download the latest firmware from Apple and restore using that instead.
