iPod & iTrip Help
Discussion in 'Headphones, Earphones & Portable Music' started by Shagga, Jan 6, 2005.
Tags:
  1. Shagga
    Shagga
    Jan 6, 2004
    265
    Middlesex
    Hi all,
    Just been using my FM iTrip in the car which has been great but how can I prevent my radio playing the iTrip ststions as tracks.....??
    Please help.
  2. mick's cat
    mick's cat
    Not sure what you mean. Can you clarify?
    The radio should display the frequency which the iTrip is broadcasting on.
  3. petecowie
    petecowie
    R.I.P.
    Sep 3, 2003
    884
    2
    Essex
    +42
    I had exactly the same problem, you have your ipod on random play and every once in a while it would play one of the itrip readio select tracks and although it doesn't change the frequeny you have to put up with the clicking and screeching for 5 secs whilst it goes through the track, the only way I found round this was to only leave 2 itrip tracks on my ipod and therefore reduce the chances of randomly picking one.
  4. paulw77
    paulw77
    Nov 18, 2000
    585
    28
    Wigan
    +43
    Or put all your tracks apart from the ITrip stations in playlists.
    This is covered in the ITrip docs/website.
  5. Shagga
    Shagga
    Jan 6, 2004
    265
    Middlesex
    Cheers guys,
    Playlist route is the way to go I think.
    Thanks again
  6. G a f f e r
    G a f f e r
    Dec 31, 2003
    3,018
    U.K.
    +628
    or... create a smart playlist. (i use one with criteria of "least played tracks" so that i get to listen to all my compiled music at least once).
    now, go into the iTrip playlist and "command" click a check mark, the station frequencies should all become unchecked (white instead of blue boxes, no tick)
    Now instruct the smart playlist to only include checked tracks......it will therefore never include the stations.
    This way, i've managed to keep all odd and even frequencies from 87.5 through to 108.0 in there (as i find that my clock radio keys into lots of frequencies well, but my dvd surround is harder to "satisfy" so i need a greater choice get one to work ------ is it just me or is it bloody hard to find ANY frequency with no cross talk or anything?,,,,
  7. Shagga
    Shagga
    Jan 6, 2004
    265
    Middlesex
    I'm mainly using 99.8 around the Uxbridge (West London area) which has been excellent thus far, particularly on my amp at home. Get the odd bit of interferance but on the whole pretty good.
    Thanks again for all the advice.
  8. simon100
    simon100
    Nov 2, 2004
    319
    +11
    I run my iTrip at 87.5 in the North West. No interference from other stations and a good clear sound. I have used the same frequency going to the South coast and through France with no problems.
  9. HMHB
    HMHB
    Nov 11, 2001
    26,732
    Nottinghamshire
    +5,493
    I'm thinking about getting an iTrip to use in the car, so what do you all think of it - is it worth getting ? What's the sound quality like ?
  10. MagicBoy
    MagicBoy
    Sep 19, 2003
    308
    +21
    Yes, it's worth getting. It can be a little fiddly when you're travelling about all over the country and need to retune it on the move because of way the frequency is set on the iTrip. It also uses a bit more battery when the iTrip on, but I've still had 6.5hrs+ with my 3G 20Gb.
    The sound quality is ... well ... good FM radio quality when it's tuned to a clear frequency and the volume is set right. Having compared the iTrip with a line-out into my receiver, the quality on line-out is better - bass goes deeper and more treble detail, but that's to be expected.
  11. mick's cat
    mick's cat
  12. jinky32
    jinky32
    Oct 17, 2004
    346
    +6
    yep, go for an iTrip, it's great for car or random hotel stays. i use 106.8 in bucks.
  13. Waser
    Waser
    Mar 1, 2004
    1,043
    Purley, Surrey
    +75
    What frequency works around London and Surrey together? I use the 87.9 default but in central London this don't work. Any suggestions are much appreciated?
  14. jinky32
    jinky32
    Oct 17, 2004
    346
    +6
    just go through the frequencies until you find one with no trace of any station (will just be that horrible untuned sound) and then use that frequency. Should get perfect reception.
  15. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,937
    2
    Manchester
    +4,457
    Just a note when setting up smart playlists - add a rule not to include any tracks less than 6 seconds, and then it won't include the iTrip tracks. :thumbsup:
  16. popester_uk
    popester_uk
    Dec 10, 2002
    316
    Brighton, East Sussex
    +9
    I use 87.7 now (download the extra freq's from griffin) and thats fine in East Sussex. get some very faint french twaddle on there occasionally, but it doesn't interfere with the itrip.
    kelvin
  17. Simon Donn
    Simon Donn
    I can recommend the Cardock FM. I bought mine and it is great. It charges and holds the ipod aswell as letting you trasmit to your car radiot.
  18. Brooktop
    Brooktop
    Feb 2, 2005
    2,104
    Nottingham
    +93
    to make sure you don't play the itunes stations on shuffle, there are details on the griffin site. You simply go to 'Get info' and check the option to skip when shuffling...although you have to select each one and keep clicking 'next' until it's greyed out.
