iPod in car
Discussion in 'Headphones, Earphones & Portable Music' started by Michaelknell, Mar 19, 2006.
Tags:
  1. Michaelknell
    Michaelknell
    Jul 1, 2005
    1,328
    41
    +15
    I've got my 60gb photo iPod which I mainy use in car with the iTrip. This is ok but the quality is quite poor. Anyone know if/where I can get my car fitted with a proper hard wired connection?
  2. Tides2002
    Tides2002
    Jul 5, 2002
    141
    +12
    It depends on your cars head unit. I have just bought a connects2 interface for my Sony HU and it makes my iPod Nano look like a big autochanger.
  3. Michaelknell
    Michaelknell
    Jul 1, 2005
    1,328
    41
    +15
    I've got a JVC in my car. I've found one for JVC's that have CD changers but mine doesn't have a changer and I can't find one for it.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    best bet is new HU then Ipod compatible ones are under £100 probably get one with the Ipod adapter for about £100
    Can your JVC take a CD changer? Whats the model number? Have you checked the connects2 webiste for compatibility? Autoleads also do similar cables
  5. Michaelknell
    Michaelknell
    Jul 1, 2005
    1,328
    41
    +15
    KD-SAC900R is the model number. What is this new HU? I don't know what that is.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    NEW HUmeans a NEW HEAD unit or in laymans speak a NEW car stereo unit the thing that goes in the DASH
  7. Michaelknell
    Michaelknell
    Jul 1, 2005
    1,328
    41
    +15
    OK. What about this? Are these good and would it work?
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    ITs an FM modulator and wont give you the best Quality Audio but it should work
  9. Michaelknell
    Michaelknell
    Jul 1, 2005
    1,328
    41
    +15
    Will it be better than the iTrip? As it's wired surely it would be pretty good. What's making it have a lower audio quality?
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
  11. Michaelknell
    Michaelknell
    Jul 1, 2005
    1,328
    41
    +15
    What sort of connector would that be? Just the normal iPod one with a jack plug type connector in the other end?
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    ipod to 2 phono cable (i think you may need an optional cable for the HU too)
  13. Michaelknell
    Michaelknell
    Jul 1, 2005
    1,328
    41
    +15
    I see, so it's plugged into the top of the iPod and not the bottom. And the other end has the white and red bits that go into the back of the CD player. That looks good. Thanks for all the help.
  14. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
  15. PJTX100
    PJTX100
    Dec 21, 2004
    8,143
    +564
    Kenwood, among others, to a connector that lets you control the ipod from the head unit (so you can stash it out of the way), show ID tags on the HU display, and charge the iPod. Also the sound quality is very good because it's a hard wire connection from the iPod line-out into the CD autochanger socket.
  16. shahedz
    shahedz
    Apr 26, 2005
    11,063
    +1,950
    check this out
    http://www.e-bowl.co.uk/products/4760.html
    it can work via your FM modulator on your car radio, or via phono in on your car radio, it has a seprate display and a seprate jog wheel which works in the same way as an ipods jog wheel. also halfords are doing it for £149.99 with free installation, brilliant machine, and a wired fm modulator works a lot better than an itrip, and i am speaking from experience of using both ,
  17. PJTX100
    PJTX100
    Dec 21, 2004
    8,143
    +564
    That looks interesting but if you add the iPod to the equation that's 4 separate bits all wired together - the iPod, controller, display, and head unit - which does make a discreet installation a challenge.
  18. kevH
    kevH
    Oct 11, 2004
    833
    Live Leeds Work Chesterfield
    +37
    Just on the subject of in car solutions im toying with the idea of hard wiring the Mrs's Nano in her car. Im thinking along the lines of the Denison Ice Link Plus and just wondered if anyone has any experience of these and firstly how they work CD changer wise .. does it disable the changer ? and is there some sort of dock seat you can use to hold it in position?
    Anyone with any experience / thoughts ????
  19. PJTX100
    PJTX100
    Dec 21, 2004
    8,143
    +564
    That Ice-link looks good and very similar to the Kenwood interface I bought which basically takes the place of the CD changer (though I believe I could have bought an adapter to allow both to work). The Denison looks like it comes with a nice dock/holder but to be honest I have wired it so that the iPod is stashed out of the way in the cassette holder in the centre tunnel - you don't need to touch the iPod because all the control and display is available on the head unit. Hence I didn't want the iPod on show.
  20. shahedz
    shahedz
    Apr 26, 2005
    11,063
    +1,950
    the ipod doesnt need to be within reach when youre using it ( because it has external controls) so most people have the ipod connection wired into the Glove box so it is out the way, you can put the display pretty much anywhere you like and the jog control is slighlty bigger than a 50 p coin isnt huge, Halfords do an excellent job of an install making it very discreet, the only things only display will be the display unit and the jog shuttle, all the cables were hidden away
  21. KiNeL
    KiNeL
    Aug 18, 2005
    333
    Essex
    +7
    What make is this as Google doesn't find it at all?
    If it's Kenwood PM me.
