Ipod/i Tunes Query
Discussion in 'Headphones, Earphones & Portable Music' started by TWOFISH, Mar 18, 2005.
Tags:
  1. TWOFISH
    TWOFISH
    Nov 24, 2004
    19
    3
    My daughter has a couple ot thousand tracks on her pc on i tunes. I intend buying my wife a mini Ipod. Now I don't know anything about IPods, and my daughter is complaining that my wifes music collection will be mixed with hers in itunes and will create downloading problems. Can my wife have a seperate itune library on the same pc?
    Thanks in anticipation.
  2. mick's cat
    mick's cat
    Yes, but you'll have to have a separate user account set up for your wife. Then all music files and the iTunes Library will be separate. If your wife and daughter listen to some of the same music this inevitably leads to a bit of duplication however.
  3. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,368
    41
    Tunbridge Wells
    +12
    If you are running XP, then I suggest your wife/daughter rip music that they want to the "My Music" folder, and any music they both want rip to "Shared Music". Then each import everything into iTunes on their respective user accounts. It is a bit off a hastle and not the most convenient way of doing this, but as far as I can see it is the only way around the problem.
  4. chalkie
    chalkie
    sound advice
