Quantcast
ipod holder for use with Denon DM38
The Foot
I have a Denon DM38 on order which has the direct USB connection to charge/play my IPOD which is great for sound quality but this means that the IPOD would have to just lay flat on the table. Is there a IPOD holder/dock that could be adapted to take the USB cable through so that you ca put the IPOD upright?
The Foot
Thanks it seems to be for the Iphone rather than the Nano but it gave me the idea to look elsewhere and I think probably one of the car holder suction types will do the trick and will probably blend in better!!
jeromeaparis
Hi, just buy a basic white "ipod cradle" on ebay for, about 3€,
or search on amazon.
Plug it to the USB of your DM38-dab that's it ;)
Jerome
