iPod help
Discussion in 'Headphones, Earphones & Portable Music' started by Pooon, Mar 24, 2006.
Tags:
  1. Pooon
    Pooon
    Dec 26, 2002
    7,543
    Canterbury, Kent
    +1,186
    Problem, my laptop that held all my music on itunes that i used to put music on my 30gbVideo ipod has died so i had to get a new one(laptop that is), but now when i connect my ipod to my new machine it wants to replace all the music on my ipod with the music in the library on the new laptop(of which there is only 1 song) so is there a way to get the music that is ON my ipod onto my new laptop?
    Thanks in advance
    Pooon
  2. kevH
    kevH
    Oct 11, 2004
    833
    Live Leeds Work Chesterfield
    +37
    Ive used a freeware programme called Ephpod, google it .
    youd can then copy all your tracks back to your new harddrive and then into your itunes library. It worked fine for me although there are other programmes that allow you to do this, try the ilounge.com forums for more info.:smashin:
  3. Pooon
    Pooon
    Dec 26, 2002
    7,543
    Canterbury, Kent
    +1,186
    many thanks KevH, i'll give that a go
  4. Davy
    Davy
    Apr 25, 2005
    376
    5
    Warwickshire
    +34
    I use PodUtil, works like a breeze and looks like iTunes too.
