Ipod Help- Car charger
Discussion in 'Headphones, Earphones & Portable Music' started by Gemz1982, Jun 16, 2005.
Tags:
  1. Gemz1982
    Gemz1982
    Hi, i was wondering if there was a way of either making an ipod car charger out of misc parts or if there was somewhere that sells them cheap, not a named brand as the ipod car chargers are well expensive.
    Gemma
  2. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,161
    38
    +7
    What's the voltage of the charger? Maplins do a multi voltage device with switchable polarity. If it's a common voltage, that should do the trick
  3. alancolledge
    alancolledge
    Feb 2, 2004
    518
    Middle England
    +5
  4. Gemz1982
    Gemz1982
