Quantcast
ipod dock with steroe 3.5 line output
simonx
my Kensington ipod dock got damaged recently - I use it for playing ipod through stereo so I bought a new one, looked on Amazon and went for this one:
http://www.amazon.co.uk/gp/product/B001HBIXSW
"he PURE i-10 universal iPod dock is that it can also be connected to absolutely any set of powered speakers, headphones or other audio systems you may have with a 3.5mm stereo line input" - I'm not overly technical and didn't appreciate the last bit of the comment! It doesn't fit my stereo - the Kensington has two connectors which go to the two (red & white) ports on the back of the stereo.
Should I return it or is there another option such as just using a different cable? Any advice/education appreciated!!
Thanks ... Simon.
Curly99
