Ipod do I need USB2
Discussion in 'Headphones, Earphones & Portable Music' started by Maidenman, Nov 4, 2003.
  1. Maidenman
    Maidenman
    I am looking at getting an IPOD and am currently using a PC running windows xp on a 2nd hand laptop I have just bought (no manuals). I have read that unless you have firewire or USB 2 it takes ages too download cd's onto the ipod. How would I know if I have either of these on my machine
  2. tvr
    tvr
    Aug 21, 2002
    443
    Bucks
    +4
    The iPods only come with a 6 pin firewire(and 4 pin converter) lead.
    You need to buy a special lead from Apple to use usb or usb2 on a PC.
    My PC laptop has a firewire or 1394? socket (4pin). Which works with an Ipod straight out of the box.
    I had to buy a firewire PCI card for my PC Tower (roughly £10 off ebay) so I can use this too now.
    HTH
    Regards
    Ryan
  3. Maidenman
    Maidenman
    thanks matey
    ok so i need to get a cable for usb however will I be disadvantaged if my pc has usb as opposed to usb2
  4. tvr
    tvr
    Aug 21, 2002
    443
    Bucks
    +4
    USB will be horribly slow!
    For around £10 you could get a PCI firewire card in your PC, and use the cable that came with the iPOD to connect it. The PC will even charge the iPOD whenever it is connected!!
  5. Maidenman
    Maidenman
    thanx tvr you r a top geezer
  6. ancientgeek
    ancientgeek
    Note tha you need 6-pin firewire to recharge the battery over firewire. Apple laptops all have 6-pin firewire, but I don't think any others do.
  7. MarkE19
    MarkE19
    Aug 10, 2002
    17,355
    Rainham Essex
    +2,441
    The standard firewire connecter on PC's & Macs is 6 pin. It's camcorders etc that have the 4 pin.
    Mark.
