iPod - Deleting from PC
Discussion in 'Headphones, Earphones & Portable Music' started by braehead, Jan 5, 2005.
Tags:
  1. braehead
    braehead
    I'm starting to run out of space on my pc and want to delete all the music I have stored on it but don't want to wipe my iPod next time I dock it. What do I do? :lease:
  2. Lester
    Lester
    Mar 4, 2001
    243
    Oop North
    +10
    Well if you're using iTunes it's..
    Edit > Preferences > iPod tab > Manually update songs and playlists
    Just wait for someone to confirm that...I'd hate you to wipe the iPod !
    Have you thought about backing-up the library to a few cd's just in case ?
  3. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,219
    48
    +61
    In addition to what Lester said, Sod's Law dictates that the iPod will break the moment you've wiped your music off the PC. I suggest an external hard disk... not just for the music but for backing up everything else. For a budget solution, buy a bare drive and a Firewire/USB2 enclosure.
  4. simon100
    simon100
    Nov 2, 2004
    318
    +11
    Given the low price of hard drives, treat yourself to a new large one and add it to your existing set up. A very easy job. Or get a DVD writer and copy your MP3's onto disks as a back up medium.
  5. ipodstudio
    ipodstudio
    Yup, like the others said, burn to CD/DVD so you have a backup or get an external HD. They're cheap these days... :smashin:
  6. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    7,806
    On AVForums
    +519
    or get rid of that pathetic excuse for software and use anapod explorer... its around £13 and is a godsend.
  7. braehead
    braehead
    Thanks folks. I think I'll go down the external drive route. Probably upgrade to a DVD RW too and make some back ups that way. Especially of my photo albums.
