Ipod connection - Please help
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by Shaqfu, Sep 4, 2007.
  1. Shaqfu
    Shaqfu
    Hi all,
    Am I right in thinking that if my head unit has an aux in connection on the front, and I'm not bothered about charging or controlling my ipod (5th gen 30GB Video) through the head unit. I can just use a 3.5mm jack - 3.5mm jack cable and plug it in to the aux in port on my head unit and the line out or headphone port on my ipod? I dont need any kind of adaptor etc?
    All I want to do is play my ipod through my head unit instead of using my current FM transmitter?
    Thanks in advance.
  2. Hooky
    Hooky
    Dec 18, 2003
    237
    +13
    normally that is correct :)
  3. davepuma
    davepuma
    Jun 24, 2004
    17,541
    +3,506
    Yes, that will work. They cost between £3 and £10 normally. Cheaper one will do. Not sure if the Apple is line out though, might be wrong on that one.
  4. Shaqfu
    Shaqfu
    Cheers guys, much appreciated.
