iPod connection cable question...
Discussion in 'Headphones, Earphones & Portable Music' started by Mikef, Apr 22, 2007.
Tags:
  1. Mikef
    Mikef
    Jun 21, 2002
    169
    16
    Maybe a dumb question, but....
    The 'normal' iPod cable has a usb connector at one end, and a wider 'ipod specific' connector at the other...can you get cables which are the wider style at both ends?
    What I want to do is link my pod up to a docking station, but...I keep my pod in a rubbery case, and I don't want to keep taking it out of the case (because I am massively clumsy, and will scratch it in no time...). I thought if I can get a connector which plugs into the bottom of the pod, then the other end is a connection 'which is pod like', ie a 'female' connector, then I can hook my pod up to a docking station without taking it out of the case...
    it all makes sense to me honest!!!
    Thanks for any thoughts...
    cheers
    mikef
  2. GBDG1
    GBDG1
    Feb 5, 2006
    7,447
    +1,260
