iPod Classic 160gb same size as Video 60gb ?
Discussion in 'Headphones, Earphones & Portable Music' started by djset, Sep 14, 2007.
Tags:
  1. djset
    djset
    Sep 18, 2005
    11
    3
    Video 60gb: 104 x 62 x 14 mm
    Classic 160gb: 103.5 x 61.8 x 13.5 mm
    Looking at the above dimensions they're almost the same size? With the exception that the classic is more curved at the edges.
    So presumably I could use the same case, dock/speakers with the classic 160gb ?
  2. daveb975
    daveb975
    Oct 25, 2002
    4,510
    103
    London
    +424
    Should be no problem for most accessories. The only issue that I have had changing from an 80GB Video to a 160GB Classic are as follows:
    Case: Perfect fit, but the much more sensitive click wheel will not operate through the case.
    FM Transmitter: Works fine, but the transmitter cannot use the iPod screen to change frequencies so I am stuck on one frequency.
