iPod AVIC problem
kwijibo
Hi all,
I have just had my Pioneer AVIC 1 with iPod interface taken out of my old car and moved to my new one. All working fine except the iPod no longer works. Well I say no longer works.....the AVIC and the iPod recognise each other, displays say as much, I can see all the artists and tracks on the iPod, I can even get it playing fine. But, and a big but, no sound. All appears fine, but no sound at all from it. I have tried numerous other iPods, all the same. The radio, Cd all work fine. Cables have been checked and look fine...run out of ideas. Anyone out there help or throw and ideas at it?
paul_mcneil
What iPods have you tried. Seen a regular problem with the Nano where the audio doesn't switch to the dock connector. You have to connect to car then plug in and unplug headphones to force it to switch
kwijibo
Thanks Paul,
It's a third gen iPod and I tried what you suggested. No luck.
