Ipod and New Hard Drive
Discussion in 'Headphones, Earphones & Portable Music' started by Bryce Curdy, Feb 23, 2005.
Tags:
  1. Bryce Curdy
    Bryce Curdy
    Apologies if this is elementary, but I'm about to buy a new laptop and am worried about the implications for my itunes library.
    If I want to add any new tracks to my ipod, will I not lose all the existing stuff next time I synch? Is there any way of copying from the ipod to the new hard drive?
    Cheers.
  2. Johan
    Johan
    Sep 13, 2003
    132
    Aberdeen
    +8
    Yes can be done.
    If windows operating system go to control panel, folder options, view, hidden files and folders click on Show hidden files and folders, click on OK.
    Then go to my computer with your Ipod hooked up to your computer, click on the ipod drive and there inside one of previously hidden files you find the folders with all your music. Copy them to your laptop.
    Hope this helps
    Johan
